Wall Mounting TV - Appliances - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 11:34 PM   #1
Wall mounting TV
I'm trying to mount my Samsung UN40EH5300F TV to the wall with a mount I've bought. On the back of the TV there are very few screw holes to which I can bolt the mount, and none of them are in the right positions.
But there are a number of what I can best describe as dimples which look to be in suitable positions, so I am guessing that they are threaded holes covered with the plastic of the TV casing, and that I can just screw into them.
However, I know nothing at all about this sort of thing and was wondering if I could get some advise from others who do know a bit as to whether my guess is likely to be correct, before I start trying to screw bolts into the back of the TV.
Thanks for any advice or tips.
Budfudder is offline   Reply With Quote
Old 03-30-2014, 11:52 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
There should be four threaded bolt holes on the back of your TV. If they aren't in the right spot, then you have an odd mount or you've done something wrong. Your TV has a VESA 400x400 mounting pattern which is pretty standard. I'd suggest you not make any holes in your TV where there aren't any already, lest you screw into a control board or part of the screen. The threaded holes are specifically designed to bear the weight of the TV. The plastic case is not.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
joecaption (03-31-2014)
Old 04-17-2014, 12:47 PM   #3
Holes should be in appropriate spots on the back of your TV. You shouldn't have to drill any plastic. Something isn't right here. I would verify that the mount you purchased will work for the size of TV that you're trying to mount.
Bortso is offline   Reply With Quote
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 08:21 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
