Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-22-2009, 08:58 PM   #1
wall heater
hello guys i have a new gas wall heater. i bought it and had a tech install it for me. problem is it shuts down and wont come back on with out a reset. if i take the cover off it works ok. i returned the first one and put in a second one with the same results. any ideas on this. thanks dave
davetel is offline   Reply With Quote
Old 02-23-2009, 07:08 AM   #2
wall heater
lack of airflow causing overheating conditions? what is the nature of the reset in other words what causes it to trip
try posting in the hvac forums
kennzz05 is offline   Reply With Quote
Old 02-23-2009, 12:04 PM   #3
wall heater
the tech was thinking the same thing and extended the vent pipe higher, but it still kicked out. he says it is burning too hot. i will try in the hvac as you remomended. thanks dave
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 01:24 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
