Wall Furnace - Appliances - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 01:04 PM   #1
wall furnace
how do you start a wall furnace?
nancy rodriguez is offline   Reply With Quote
Old 08-17-2010, 07:26 PM   #2
Rewards Points: 6,652
Is this a rental, or do you own the place of residence that this unit is in? If it has not been lit since you have been living there, get a reputable HVAC guy to look over the unit to make sure that it will work. Wall heaters, or Wall furnaces are the most inefficient and unsafe appliances that where invented. You might as well turn on the oven and let it run 24x7.
The Following User Says Thank You to gregzoll For This Useful Post:
fabrk8r (08-18-2010)
Old 08-18-2010, 05:38 AM   #3
yeah-ditto-for safety- get it checked first.
Jacques is offline   Reply With Quote
Old 08-18-2010, 08:19 AM   #4
fabrk8r
fabrk8r's Avatar
I thought about commenting on this thread yesterday when I first read it, but wasn't sure how to put into words how I felt about these appliances.
Thank you gregzoll for saying what I should have.
Please, if this is a NG or propane fired heater, at least have someone check the unit to make sure it is safe and operating correctly before trying to start it. CO poisoning is a major concern with these units.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Chimney vented wall furnace JohnH1 HVAC 3 12-22-2009 07:54 PM
Upgrading wall furnace Wanttodoitright HVAC 2 03-20-2008 05:57 PM
Wall furnace blowing out kwoodsong General DIY Discussions 5 12-09-2007 06:14 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
