Vertical Dryer Venting - Appliances - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 04:00 AM   #1
Vertical dryer venting
Hello,
Can dryer vents have vertical runs in them? I'm trying to figure out the best way to vent my dryer, and it would work best if I could have a vertical run from the back of the dryer to my garage ceiling, which is about 8 feet. 90 degree turn from there and continue another 20 feet. I know that exceeds the max recommended length, but is it doable and safe or should I scrap that idea?
Thanks.
oatlord is offline   Reply With Quote
Old 04-04-2011, 06:55 AM   #2
Should be fine. use rigid, at least, on the 20' run with foil tape[no screws] and a good hood.
Jacques is offline   Reply With Quote
Old 04-04-2011, 07:25 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Vertical is fine...20' is pushing it.
x2 on the rigid
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 01:10 PM   #4
Rewards Points: 6,652
8, plus the 90 (would add 5'), then the 20, would make the run 33 feet.
Old 04-04-2011, 01:26 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
This, and you may want to add a booster fan as well. You'll want it to be in an easily accessible location so it can be checked for any lint clogs every now and then.
Venting A Dryer Adam9182 Building & Construction 2 10-23-2010 08:14 AM
dryer venting too short? Mike L Appliances 11 09-23-2009 11:26 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 11:53 AM
Venting Dryer Through Roof Thirdeye General DIY Discussions 1 03-04-2007 11:06 AM
