-   -   Vertical dryer venting (http://www.diychatroom.com/f47/vertical-dryer-venting-100475/)
oatlord 04-04-2011 04:00 AM
Hello,
Can dryer vents have vertical runs in them? I'm trying to figure out the best way to vent my dryer, and it would work best if I could have a vertical run from the back of the dryer to my garage ceiling, which is about 8 feet. 90 degree turn from there and continue another 20 feet. I know that exceeds the max recommended length, but is it doable and safe or should I scrap that idea?
Thanks.
Jacques 04-04-2011 06:55 AM
Should be fine. use rigid, at least, on the 20' run with foil tape[no screws] and a good hood.
tcleve4911 04-04-2011 07:25 AM
Vertical is fine...20' is pushing it.
x2 on the rigid :yes:
gregzoll 04-04-2011 01:10 PM
8, plus the 90 (would add 5'), then the 20, would make the run 33 feet.
Red Squirrel 04-04-2011 01:26 PM
This, and you may want to add a booster fan as well. You'll want it to be in an easily accessible location so it can be checked for any lint clogs every now and then.
