Venting Dryer Directly Downwards - Appliances - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 08:09 PM   #1
Doozer
Rewards Points: 123
Venting dryer directly downwards
I need to vent my dryer through the floor. The floor is 3x6 T&G fir. Beneath that are joists, logs, and the river is 2 feet below the floor. So it really doesn't matter if I am venting moist air beneath the house. The wind will blow it away.
What I really want to know is: does anyone know of a termination which will allow the dryer to vent, but which will keep pests out? I can easily poke a hole in the floor and stick a duct down, but what do I put on the bottom of it? Standard dryer vent fittings are made to go through a wall and have a flapper that closes when the dryer is not running. That will obviously not work for me. Is there a nice fitting or should I just bend some hardware screen over the end and put a couple of screws in it?
Thank you.
FatBear is offline   Reply With Quote
Old 08-30-2013, 08:32 PM   #2
K&B Designer
Live_Oak's Avatar
The damper is spring loaded and opens with enough air pressure from the dryer. You do need to have access to this from the exterior as it requires periodic maintenance. Especially with the added humidity. Lint accumulates and will block the air's exit resulting in your dryer element burning out or even a house fire.
Live_Oak is offline   Reply With Quote
Old 08-31-2013, 04:03 AM   #3
Rewards Points: 13,712
Use solid pipe and pop rivets, add an elbow and use a standard vent cap.
I like the ones I've found at Lowes that have a flap but no screen to get clogged up.
http://www.lowes.com/pd_328919-85334...Ntt=dryer+vent
Also the ones with louvers always hang up and plug up with lint.
Old 08-31-2013, 06:29 AM   #4
Rewards Points: 3,130
I know it's against code to use screws on dryer vent pipe. Is it really OK to use rivets? Just curious.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Dryer venting options SuperJETT HVAC 4 11-28-2012 12:20 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 11:53 AM
