Ventilation Behind Wall Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 03-17-2015, 09:17 AM   #1
Rewards Points: 152
Ventilation behind wall oven
I removed the old wall oven:
Put in the "new" one. The open space above used to hold a convection oven when we first moved in, now just a microwave.
Here's the top of the new oven. There's a small fan off the back that runs when it's on, something the old one didn't have.
This is the ceiling of the open space where the microwave goes. Note the vents cut in, they were there with the old oven. They vent through the cupboard above and out into the kitchen.
There was a piece of foil backed insulation stuffed between the oven and the microwave area.
Couple questions:
- do I need the insulation? Seems like it would block any ventilation, rendering the fan on the back useless. I did check the manual but it doesn't say anything.
- Any idea how much ventilation area I need? I would like to close in the floor above the oven a little bit so we stop losing kitchen mitts, skittles, etc down the back.
Thanks!
burnt03 is offline   Reply With Quote
Old 03-17-2015, 11:11 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
I've never seen a wall oven with vents cut into the cabinet like that, pretty sure the previous homeowner just thought it was a good idea. It is totally unnecessary .
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
oh'mike (03-18-2015)
Old 03-17-2015, 11:12 PM   #3
#1 HAWKEYE FAN
FYI that fan is to cool the electronic board
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
wiring wall oven roye Electrical 5 01-26-2012 08:14 PM
only 1/4 inch of frame & wall on each side of wall oven tentativentexas Appliances 1 09-27-2010 07:56 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
