Vent Hose Is Preventing Dryer From Pushing Back - Appliances - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 12:23 PM   #1
Vent hose is preventing dryer from pushing back
Hi everyone! I have a small laundry room and the silver vent dryer hose is preventing the dryer form going against the wall. The dryer comes out about about 4inches farther than the washing machine. It's really awkward with the doors and narrow walking space. There is nothing preventing the dryer from moving back but the hose. Is there an alternative to such a bulky vent hose?
DreaminginTexas is offline   Reply With Quote
Old 12-02-2013, 12:44 PM   #2
PoleCat's Avatar
Rewards Points: 1,652
You could custom build a rectangular duct and secure it to the back of your dryer so it would mate with the outlet when pushed back.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
DreaminginTexas (12-02-2013)
Old 12-02-2013, 01:41 PM   #3
This is not the only company that makes these. You can get similar ones at your local hardware store.
http://www.dryerbox.com
johnapotamus is offline   Reply With Quote
The Following 2 Users Say Thank You to johnapotamus For This Useful Post:
747 (12-02-2013), DreaminginTexas (12-02-2013)
Old 12-02-2013, 04:27 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
http://www.homedepot.com/p/Whirlpool...8#.Up0I7ifxRpU
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
DreaminginTexas (12-03-2013)
Old 12-02-2013, 04:35 PM   #5
Rewards Points: 2,076
How about cutting 4 inches off of the hose.
Old 12-02-2013, 05:14 PM   #6
great ideas! thanks everyone!!! I'm really excited about a few of these suggestions!! THERE IS HOPE lol.
Old 12-03-2013, 07:07 AM   #7
Rewards Points: 1,300
Are the outlet of the dryer and the inlet pipe in the wall lined up with each other? If so, ditch the hose and put in a short piece of metal duct pipe. The shorter the distance the better.
danpik is offline   Reply With Quote
Old 12-03-2013, 07:42 AM   #8
Rewards Points: 3,130
That's what I did. But I built my house myself so could put the hole in the wall exactly where I wanted it. The exhaust pipe is less than 1 foot long; would be shorter except the walls are 6 inches thick (logs).
Old 12-03-2013, 01:44 PM   #9
43 years in construction
Arkitexas's Avatar
Check the sides of your dryer. Many models come with a side discharge option. Using side discharge you could then push the back nearer the wall. Such models will have a 4" diameter metal knock-out on the sidewall, usually near the floor. Drawback is that it will require 5" to 6" spacing to the sidewall or washer.
Arkitexas is offline   Reply With Quote
The Following User Says Thank You to Arkitexas For This Useful Post:
Old 12-03-2013, 02:20 PM   #10
nope they are not lined up...one is in one corner and the other is down in the other...makes half an X
Old 12-03-2013, 11:02 PM   #11
Registered User
Rewards Points: 526
Be very careful about using some adapters;
Verify; http://www.dryerbox.com/ratings/dryerfittingschart.htm
Gary
Old 12-04-2013, 12:30 AM   #12
Rewards Points: 199
Every house I've lived in had this problem. I hate it. I recently upgraded with the "dryer box" mentioned above. I got the metal one from Amazon.com and it should last the life of the house.
Arlo is offline   Reply With Quote
Old 12-04-2013, 12:49 AM   #13
Rewards Points: 6,652
Gary
I changed out my mushroom vent, which when I got it, had to sand down the sides of the cup, to allow it to move freely. That is the largest problem, with it having bad ratings. The issue with the cup not freely moving, causes back pressure. The old units actually used a ball vs. the cup.
I went with the No nest, due to in the three years I had the mushroom style, it was getting banged up pretty good, due to getting knocked with the mower handle all of the time.
On the offside, the No Nest actually chatters when the dryer is running, so it makes more noise.
I do find these studies tend to be one sided, due to there are no other metrics to verify the results from that study.
As for the OP, they really need to post pictures of the issue at hand.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Low clearance dryer vent solution? miamicuse HVAC 9 11-22-2012 07:26 PM
Floor dryer vent won't allow enough room for dryer kay-d Appliances 4 07-13-2012 03:09 PM
Flat dryer vent code??? duct Chemist1961 Appliances 3 10-24-2010 04:49 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
