Vacuum Recommendation - Appliances - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 06:35 PM   #1
Rewards Points: 2,152
Vacuum recommendation
Walmart is the only store around. With that in mind does anyone have any suggestions for a reasonable vacuum.
Visiting one of my kids and their vacuum doesn't work. (Explains the dusty floors)
Bare floors, wood and vinyl except for one room with low nap.
Startingover is offline   Reply With Quote
Old 02-10-2014, 07:07 PM   #2
Rewards Points: 756
A stick vac, or the equivalent, would be great for bare floors and low nap.
I use a 40+ year old Electrikbroom.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
Startingover (02-10-2014)
Old 02-10-2014, 07:10 PM   #3
Rewards Points: 252
Bissell makes a pretty good vacumm for hardwood, vinyl, and low nap floors. I believe they are available at Walmart. Pretty reasonable price wise. In between cleanings we also like using a swiffer.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Old 02-10-2014, 08:19 PM   #4
Rewards Points: 236
get one that you can turn the brush off. they work better on hard floors.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 02-10-2014, 08:39 PM   #5
Thanks for helpful responses.
I also wonder about bagless. Would dust fly all over when you empty them. She's an Ultra marathoner so no time for trivial things like buying bags. 🏃 lol
The Following User Says Thank You to Startingover For This Useful Post:
eppelralph (03-04-2014)
Old 02-10-2014, 09:07 PM   #6
msaeger's Avatar
Rewards Points: 260
I have had both and like one with a bag better. Dumping the bagless ones was messy and I don't need to replace the bag that much.
msaeger is offline   Reply With Quote
The Following 2 Users Say Thank You to msaeger For This Useful Post:
oh'mike (03-22-2014), Startingover (02-11-2014)
Old 02-10-2014, 10:13 PM   #7
Rewards Points: 236
the bagless can be messy. i dump mine outside, in the garbage can of course.
and they do need to be cleaned or they plug up.
Old 02-19-2014, 10:38 PM   #8
Rewards Points: 276
I bought the Eureka that Walmart sells for around 120 that claims to be better than a Dyson. It has clog proof technology similar to the Dyson and is pretty good for the money. I don't know if it is actually better than a Dyson as they claim but it doesn't cost 400-500 dollars either.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Startingover (02-21-2014)
Old 02-24-2014, 11:25 AM   #9
Rewards Points: 147
I have a Dyson. It's a very good vacuum with massive suction but it is expensive. I probably wouldn't spend that much again. It's bagless of course but not messy. You push a trigger and the door drops down releasing the contents. I suppose if you shook it violently you'd have problems but I like getting away from buying bags.
Rango is offline   Reply With Quote
Old 02-27-2014, 08:09 PM   #10
Lord of Slums
Rewards Points: 1,974
i bought that cordless hoover and it seems fine
mj12 is offline   Reply With Quote
Old 02-28-2014, 06:56 AM   #11
Rewards Points: 3,130
We used to buy all our vacuums at Walmart or somewhere similar. After trying (and buying) a "real" vacuum (a Miele), it's clear that all the others we owned were junk.
Old 02-28-2014, 12:26 PM   #12
On the Road Less Traveled
The Jeep Driver's Avatar
Rewards Points: 91
Our Kenmore vacuum was on the fritz after over 15 years of use. My sister brought her Shark bagless over for us to try out. We thought it was a great machine, and bought one. The best deal I found was on QVC, I linked the Shark we got for you if you'd like to check it out. There was a good deal on Shark's web site as well, but it came with the floor mop/steamer, which we already have. Our home is 100% tile, wood or concrete, and the Shark does the job.
The Jeep Driver is offline   Reply With Quote
Old 02-28-2014, 12:37 PM   #13
Rewards Points: 1,452
Shark Rotator is pretty good. Kind of like a Dyson, but under $200.
mikegp is offline   Reply With Quote
Old 02-28-2014, 12:59 PM   #14
Rewards Points: 1,010
Ditto on the Shark
I have a Dyson and while it is a good vacuum, there are other models using the same technology and perform just as well but cost half of what a typical Dyson costs. My gf bought a Shark last year and she really likes it.
spaceman spif is offline   Reply With Quote
Old 03-01-2014, 06:04 AM   #15
Rewards Points: 12
check out vacuums at amazon.com. they have many types you can choose complete with reviews from buyers
atun willis is offline   Reply With Quote
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
Water Heater Vacuum Breaker Needed??? Trgo Plumbing 1 10-21-2012 06:34 PM
Central vacuum issue omgwtf Appliances 6 10-14-2012 08:05 AM
Outside Faucet Vacuum Breaker - defeat or remove? tjtv Landscaping & Lawn Care 2 09-27-2011 05:49 PM
Inducer Vacuum Problem RobertCan HVAC 21 12-22-2009 03:20 PM
