Use Freezer As Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 02:18 PM   #1
Use freezer as fridge
I have an old freezer. Can I just plug the freezer into a timer and just have the freezer run for maybe 2-3 hours a day to keep my beer cool. Yes, it will be used for a beer fridge
fjacky is offline   Reply With Quote
Old 11-29-2010, 07:42 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I suppose it could work. What I'd do (voiding the warenty in the process) is run some kind of thermostat inside that activates a relay to turn it on/off. That way you can have better control of the temp.
Old 11-29-2010, 07:52 PM   #3
Yes, there have been a number of articles describing how to do it, for example:
http://www.builditsolar.com/Projects...est_fridge.pdf
PS. How you void the warranty on an old refrigerator? They don't have one.
PastTense is offline   Reply With Quote
Old 11-29-2010, 08:18 PM   #4
Do it right.
As long as it's frost free. If not, you'll end up with a bunch of water on your feet every time you want a beer.
SubSailor is offline   Reply With Quote
Old 11-30-2010, 11:08 AM   #5
Don't think it's frost free, that's why I was gonna put it on a timer, hoping it wouldn't be on long enough to create the frost. Just long enough to keep it cool. I guess not the best idea. I tried
Old 12-01-2010, 11:23 AM   #6
If I do end up converting this freezer into a fridge, would it ruin the compressor if I sat the freezer up so the lid would open as a door and not as a typical chest freezer?
Old 12-01-2010, 03:50 PM   #7
Rewards Points: 476
I belive you can't do that the compreser set's on spring's and it would fall out of the set up and the compreser has to set down like it is sopose to oil in the comp would i belive lock up the reed valve's and maybe the filter. Lot's could happen. my 2 cent's got to get a beer
del schisler is offline   Reply With Quote
Old 12-01-2010, 09:57 PM   #8
jlhaslip's Avatar
Rewards Points: 2,134
Beer never lasts long enough to enjoy the 2 hour cycle you are planning for...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 12-02-2010, 10:26 PM   #9
WDR
compressor
I believe the oil in fridge / freezer compressors oil squirts up through the middle and flows over the motor and actual compressor back to the bottom. If you turned it on its side the oil whould not flow over the whole unit and it would over heat.
WDR is offline   Reply With Quote
Old 12-03-2010, 07:08 AM   #10
go to a local appl parts store and buy a temporary cold control Eaton- #CC1. it has it's own hse with knob and suction cups. connect the old thermo wires to this and set it for refrig temps. the condenser coils are inside the liner so don't drill holes through it to install a tap..don't turn it on end either.
Jacques is offline   Reply With Quote
Old 03-14-2013, 05:08 AM   #11
An old Tradesmen
Rewards Points: 7,328
That would kill the compressor.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 07:59 AM
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 05:38 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-22-2008 11:36 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
