Upper Spray Arm Fell Off - Appliances - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 03:48 PM   #1
Rewards Points: 137
Upper spray arm fell off
I have a Frigidaire Gallery dishwasher model number BGHD2433KW0 purchased in September 2009. Yesterday the upper spray arm fell off. How would I go about re-attaching it? Thanks in advance for any assistance.
bucksone is offline   Reply With Quote
Old 01-23-2011, 03:57 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a lot of them simply pop on and off. You will need to look at the arm and the spout to determine what holds it on.
make sure the spray ports are clear. If they are plugged, that would allow a buildup of pressure which might have popped the spray arm off.
Old 01-23-2011, 05:52 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
i think the Frigidaire has a little button with tabs on it that holds the arm on
hardwareman is offline   Reply With Quote
Old 01-23-2011, 06:02 PM   #4
nap
You talking to me?
nap's Avatar
I suppose I should have researched this a bit first but:
ftp://ftp.electrolux-na.com/prodinfo...5995551172.pdf
I believe that is the correct unit. It looks like the upper spray arm might actually be threaded onto the supply pipe with the supply pipe being on the outside of the tub and the spray arm (obviously) on the inside.
Old 01-23-2011, 07:08 PM   #5
#1 HAWKEYE FAN
yeah, that is actually 2 pieces. the nut screws onto the deilvery tube and then that little button underneath snaps on to hold the arm on, but I'll bet you need the whole arm to do a proper fix, that little button usually breaks.
Old 01-23-2011, 07:31 PM   #6
nap
You talking to me?
nap's Avatar
that place was listing it as a unit. I didn't see either piece individually. I would guess if the arm came off the threaded piece, it would be considered to be broken.
Old 01-26-2011, 02:44 PM   #7
Rewards Points: 137
So, the upper spray arm was in fact, broken. I bought a new one, installed it, and the problem is resolved. It's nice to fix something with only a $10 part and the help of this forum. Thanks once again.
dishwasher ddddsmith Appliances 1 09-27-2010 03:36 AM
Looking for a kind of pest killer spray userid Pest Control 1 05-04-2010 07:06 AM
BIN Spray Shellac-Base Primer formulation PAINTLOVER Painting 0 05-01-2010 09:54 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 12:58 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
