Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-23-2008, 04:11 PM   #1
Unhappy
uninstalling a Goldstar microwave
Hi, I am trying to uninstall a Goldstar microwave over that is mounted on the wall under a cabinet. I removed all screws that I can but somehow the unit does not budge. I removed the 2 screws from the top cabinet, open the front but cannot find what is locking the unit in place.
Any idea would help.
Thanks.
JJo.
JJ@Bellamy.net is offline   Reply With Quote
Old 10-23-2008, 07:58 PM   #2
What can I find here?
Winchester's Avatar
Is it vented to the outside?
Winchester is offline   Reply With Quote
Old 10-23-2008, 08:23 PM   #3
right now the fan goes in the kitchen, which is why I want to take it out to change it to venting through the ceiling.
Old 10-23-2008, 08:45 PM   #4
Winchester's Avatar
I've installed a couple microhoods and they usually hinge on the bottom of the microwave on the back wall to a metal plate. From memory it only seems as though there were 2 bolts up in the cabinet. Are there possible 4 total or two more in the rear of the cabinet?
Would there possibly be some grease build up that is holding it in place?
Old 10-23-2008, 08:58 PM   #5
I checked and removed all screws but to not avail. Somehow, I think that the oven is locked in the place but since I don't know how, I don't want to pull too hard because I will need to put it back in place after I change the venting system.
I cannot see anymore screws, any levy, anything that can let it go ??????
Tags
install microwave, uninstall microwave
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
Is Leah crazy? Could my microwave kill my WiFi Leah Frances Electrical 10 02-29-2008 06:11 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
Microwave turning on Central Air!!? Sean F HVAC 7 06-21-2007 09:15 AM
Microwave turning on Central Air!!? Sean F Appliances 1 05-23-2007 11:44 AM
