Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-12-2009, 09:08 PM   #16
Xtreme DIY'r
Turning off washing machine faucets when not in use?
They have had problems with those bursting too
I would not buy one & trust it
Old 12-12-2009, 09:40 PM   #17
sdsester's Avatar
Originally Posted by paul100 View Post
They now have a braided metal hose with a valve in the water supply end that can sense when the hose has burst. It will shut the water flow off. I cant remember the name of them but they can be found at HD or Lowes.
Hugh?
sdsester is offline   Reply With Quote
Old 12-12-2009, 09:50 PM   #18
Xtreme DIY'r
Originally Posted by sdsester View Post
Hugh?
There are different brands
The inexpensive one he is talking about fails, just a pressure sensing device
They may have fixed the problem, but the connections were failing
They also have electronic ones that monitor the pressure
Not sure how well they work
Watts Intelliflow - $150
http://www.keidel.com/mech/pvf/valve-laundry.htm
Old 12-12-2009, 10:11 PM   #19
Xtreme DIY'r
Watts floodsafe is the cheap hose that has pressure sensing shutoff
Problem is the whole connector snaps off
Old 12-12-2009, 10:30 PM   #20
sdsester's Avatar
Like I suggested, it seems to me the way to avoid problems is with an automatic cut-off valve situation. Rubber or whatever line to the washer cannot burst or cause problems if there is no water or water pressure in it when it is idle?
Old 12-12-2009, 10:35 PM   #21
Did that happen at your house? Did that break just from the pressure or was the hose under strain from being bent or pulled? I have that brand on my house. I might need to change them.
paul100 is offline   Reply With Quote
Old 12-12-2009, 10:41 PM   #22
Xtreme DIY'r
Not my house, pic from another forum
$25k in damage, it snapped under normal pressure
2nd one this plumber personally saw that failed
Poor quality
Old 12-13-2009, 12:00 AM   #23
sdsester's Avatar
Having a dumb moment I suspect but how does a hose sense it is in trouble and shut of the valve to which it is attached? If HD or Lowe's sells them they must be real?
See a post a few back where what I think you are talking about completely failed.
Valves turn water on and off. Not hoses I have found so far.
Invest in automatic cut-off valves.
Old 12-13-2009, 12:33 AM   #24
At the supply end of the hose ther eis a valve in it. It is a spring loaded disk or ball. Under normal use the water is not flowing at full volume and the spring can hold the ball open. If a break occurs then the water is flowing at a much greater volume and it pushes the ball down and shuts the flow off.
Old 12-13-2009, 12:49 AM   #25
sdsester's Avatar
Got it now but I think I would really rather put faith in the valve? Trusting all this to the hose seems rather like stapling through condoms to the use instructions for them? If the hose is failed why would I not want the water supply to it shut down? Seems like this hose concept put a lot of faith in itself and still not the valve?
Old 04-12-2010, 09:35 PM   #26
I never realized it was the norm to shut these valves off. We never have and have never had a problem with the hose rupturing. The problem in my house is that the kids would forget to turn it off after use or forget to turn it on before use.
It may have prevented the problem I now have with a common type of brass double valve that does not want to shut off completely.
Does anybody know of a fix to this problem that does not require replacing the whole thing?
Jim F is offline   Reply With Quote
Old 04-12-2010, 10:21 PM   #27
Xtreme DIY'r
Another problem with the auto-sense shut off valves:
--some washers - possibly combined w/high water pressure ?
--were causing the auto-sense valve to shut down
--this then required the user to depressurize the hose before it would work again
MIL had a single handle shut-off installed & uses that
I plan on installing one
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
