Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-29-2009, 03:28 PM   #1
Turning off washing machine faucets when not in use?
I recently read that the washing machine hot & cold faucets should be turned off whenever the machine is not in use.
I guess this sounds like a good idea, but I was just wondering how many people actually do it. I've never turned them off. Am I the exception or the rule?
markinmich is offline   Reply With Quote
Old 11-29-2009, 03:30 PM   #2
I turn mine off every time I'm done with the washer. Saves me the chance a hose splits and dumps water all over my floor for untold hours until I discover the problem.
markwo is offline   Reply With Quote
Old 11-29-2009, 06:27 PM   #3
I turn them off, actually is one lever to push over to off. It only takes one busted hose to happen to cause a big expensive mess. I understand its a pain if the controls are not easily reached but its still safer to shut them off after use.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-29-2009, 06:42 PM   #4
It was a dark and stormy
Yoyizit's Avatar
I use those hoses with the metal braided sleeve.
Old 11-29-2009, 08:42 PM   #5
Wire Chewer
Red Squirrel's Avatar
Same here - with teflon tape, and I put them on pretty tight (by hand, not to overdo it). I originally bought the rubber hoses then I opened one and it was broken in the bag! I returned it for another, then as I was installing them I decided to just go buy the metal ones. I mean, if it broke in the bag, what is 100+ PSI of water going to do to it? Was probably defective, but still scared me.
Ended up using the rubber hose for my wash sink, so it still serves a purpose. The other one is on a shelf and I might hook it up to my dehumidifier some time. Need to add a garden hose tap to the tank.
Old 11-30-2009, 03:51 AM   #6
paper hanger and painter
chrisn's Avatar
The braided ones can and will bust also. I turn mine off after use, safety first.
Old 12-01-2009, 12:24 PM   #7
47_47's Avatar
Chrisn is right. The metal braid is just a covering over a rubber hose and they can burst. We turn ours off.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 12-01-2009, 04:38 PM   #8
Yoyizit's Avatar
I thought the idea of the metal braid was to keep the hose from ballooning out and then bursting. No ballooning, no catastrophic failure?
I'd hope they can at least withstand pressure longer and fail more gracefully than a non-reinforced hose.
They must be good for something 'cause at the beginning there were 'counterfeit' hoses being offered. These things had plastic braid that looked like fine metal wires, except that the color was off.
Old 12-02-2009, 10:36 AM   #9
LeviDIY's Avatar
Wow... I love this site... I would have never thought to do this.
LeviDIY is offline   Reply With Quote
Old 12-07-2009, 06:49 PM   #10
I turn the water supply to the washer off every time I am done with it, but never worry about flexible pipes under the kitchen sink<g>.
There are several under there for the water filter, but they're hard plastic, not hoses.
FW
KE2KB is offline   Reply With Quote
Old 12-09-2009, 12:19 PM   #11
long island, NY
I never knew those metal braided hoses could burst..... I think I'll start turning off my faucets after the wash.....
diy'er on LI is offline   Reply With Quote
Old 12-09-2009, 12:56 PM   #12
HarryHarley
HarryHarley's Avatar
Never turned off the water in 35 years. I would have to pull the washer away from the wall. I do change the hose every 5 years or so. Always used the braided ones.
HarryHarley is offline   Reply With Quote
Old 12-10-2009, 05:56 AM   #13
sdsester's Avatar
You can buy an electronic valve that turns your water supplies to the washer on and off as you use them. I had a plumber do the installation for a client who traveled a lot and installed a second small laundry upstairs in a renovation and didn't want to risk new floors. I just called in the plumbing subcontractor I use so have no idea what is involved or what the thing cost but but suspect it might well be worth it? Compared to a washer fail on a third floor renovation? A flooded basement? Google for automatic washing machine cutoff valves. I don't know of this is the brand used or not but this link will give you an idea of the concept.
http://www.keidel.com/mech/pvf/valve-laundry.htm
Supply lines are another one of those things I would not buy from a box store but from a plumbing supplier instead. They may be no different but it gives me false security having things handed to me and not in a packaged in China bag. Definitely replace them every few years and for sure turn them off between uses if you remember and have the patience. And always when you go on vacation!!!
And one other tip? With an id of 1/2" or less? You can only flow water at x gallons per minute through the capacity no matter how you try to push it along. You achieve nothing but stressing out the tubin, like forgetting to turn a garden hose with a hose nozzle on the end overnight, with the valves all the way open and forcing the full psi your water supply probably has to offer at it. And remember, the valve on modern washer is likely plastic fantastic (and not even PVC) and pressure regulating and has a stress point too. It makes no sense to put 80psi or whatever your home water pressure is (and you should measure so you know) has against it 24/7/365?
sdsester is offline   Reply With Quote
Old 12-10-2009, 11:44 AM   #14
Yoyizit's Avatar
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
Old 12-12-2009, 09:03 PM   #15
They now have a braided metal hose with a valve in the water supply end that can sense when the hose has burst. It will shut the water flow off. I cant remember the name of them but they can be found at HD or Lowes.
paul100 is offline   Reply With Quote
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
