Troubleshooting Kenmore Dishwasher Leak (video) - Appliances - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 04:50 PM   #1
Troubleshooting Kenmore Dishwasher leak (video)
We have a Kenmore Elite #665.13759K602 that has begun to leak. Water drips down onto the supply hookup as well as surrounding wiring. The leak is slower when the tub is filling, and worse when it is not. It is definitely a supply-side issue because it does not leak once the supply is shut off and leaks even if the tub is empty (before the dishwasher is run). It leaks constantly any time the water supply is on.
Here is a video of the leak in action:
Any ideas of what I should look for? I want to do the repair myself.
Thanks!
Daddie0 is offline   Reply With Quote
Old 01-07-2011, 04:58 PM   #2
Experienced
Jackofall1's Avatar
Its either the fill solelnoid or the pump, realitively easy fix for either.
Old 01-07-2011, 05:52 PM   #3
JackofAll-
Based on what you said I'm thinking fill solenoid (like a housing crack or something) since it starts leaking as soon as the supply water is turned on (and while the machine is still off). Does that make sense? If it was the pump, would it still leak even with the machine off? I wouldn't think anything past the solenoid could leak until the dishwasher ran.
I have to order my parts online, and want to make sure I get what I need.
Thanks for the quick reply!
Old 01-07-2011, 07:32 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
hard to say for sure, your camera work is not really getting a good shot at the solenoid, but I'd have to say the fill valve is the problem
hardwareman is offline   Reply With Quote
Old 02-04-2011, 11:18 PM   #5
Thumbs up
Fixed!
Just a quick follow up: you all were right, it was the solenoid. I pulled the dishwasher, removed the solenoid and hooked it back to the water line all by itself. Applied pressures and a pretty little spray came straight from the housing.
I'm only posting the follow up in case others see the same thing. Since the crack was on top of the solenoid it looked like the water was "dripping" from somewhere.
Huge THANKS to all those who took time to read, think, and reply!
PS The delay in my post is because I had to replace the floor too, and this kinda got buried in my list of TTD.
Old 02-05-2011, 08:45 AM   #6
#1 HAWKEYE FAN
thanks for sharing, its good to know we can help.
Old 02-05-2011, 08:54 AM   #7
Experienced
Jackofall1's Avatar
Thanks for posting back, most don't.
Mark
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 07:39 PM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Kenmore Portable Dishwasher Won't Drain - PLEASE Help! katb1030 Appliances 8 07-10-2008 12:38 PM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 10:35 AM
