Troubleshooting Gas Burner - Appliances - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 12:52 PM   #1
Rewards Points: 14
Troubleshooting gas burner
One of the burners, the large center one, one my Bosch gas cooktop won't light itself. I can easily light it with a lighter, so there's definitely gas flowing. It clicks, and I can see a spark from the igniter, but it never actually lights. This seems like a very simple mechanism, so I'm not clear on what could be going wrong. What should I do to troubleshoot this? The rest of the burners light fine.
murphybad is offline   Reply With Quote
Old 06-16-2012, 01:36 PM   #2
Missouri Bound's Avatar
Clean all the burner holes and the gas tube leading up to the burner.
Do you want it your way or the right way?
Old 06-16-2012, 01:59 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
that would either be a weak ignitor or most likely the 3 little holes directly below or above your ignitor are plugged. Get a pin and clean them out.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-16-2012, 03:08 PM   #4
Rewards Points: 83
Like said already clean the holes. you can also take a bit of emery cloth and clean the igniter. Some models have a flash tube, they need to be properly positioned as well.
If that doesn't fix it, Most likely the spark igniter. Just because something sparks does not mean it will ignite.
Protocol. is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 09:53 AM
Troubleshooting Becket Burner DesDevInc HVAC 0 04-18-2011 06:53 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
radiant burner troubleshooting steve1234 Appliances 1 03-14-2008 01:16 PM
