Troubleshoot Ge Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 09:37 AM   #1
troubleshoot ge washer
how can you tell if clutch is bad on a GE washer?
stontonker is offline   Reply With Quote
Old 03-23-2013, 09:51 AM   #2
Rewards Points: 13,968
What's it doing wrong? Got a model #
http://www.repairclinic.com/RepairHe...ne-Repair-Help
Old 03-23-2013, 10:03 AM   #3
dont have model # yet but its a super capacity plus/heavy duty washer, 21 cycle. it makes a ROARING noise when spinning. sometimes it doesnt spin but just 1 article at a time. it wont spin anymore with full load. belt looks new.
Old 03-23-2013, 10:12 AM   #4
model WLSE4210AOWW
Old 03-23-2013, 10:19 AM   #5
http://www.repairclinic.com/RepairHe...ing-loud-noise
stontonker (03-23-2013)
Old 03-23-2013, 03:24 PM   #6
Rewards Points: 6,652
It will make a grinding noise, there will be oil on the floor, and it will not agitate, or go into spin cycle. Also keep in mind, a lot of times, it is just the rubber & plastic coupling that is bad, not the transmission.
You actually get the new clutch with the new transmission http://www.repairclinic.com/Transmis...AOWW-%3d%3dc25 It is cheaper than having to purchase each item separate.
Switch Washer & Dryer Position? Anianna Appliances 5 12-12-2012 10:55 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
