Trouble Shooting Freezer Defrosting Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 06:51 PM   #1
Rewards Points: 22
Trouble shooting freezer defrosting issue
Hello everyone. I am having an issue with my freezer not defrosting. It is building up frost on the coils and not staying cold enough to keep things frozen. I have done some research and it appears that it could be either an issue with the defrosting heater, the timer or the control switch for the heater. Is there a way to trouble shoot these items myself with a multimeter or some other device to determine where the break in the system is? Also does anyone have any idea how much either one of those parts would cost to replace?
I have attached a picture if the label inside the fridge so you can see the model #. This is a bottom freezer model and is about 10 years old.
johnnybeltway is offline   Reply With Quote
Old 08-03-2013, 07:15 PM   #2
Rewards Points: 12,830
http://www.repairclinic.com/RepairHe...ng-59672913200
johnnybeltway (08-03-2013)
Old 08-04-2013, 09:54 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
I have replaced dozens of heaters that were crushed by solid ice when the drain became clogged. Good place to look first.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 08-04-2013, 06:22 PM   #4
Oso954's Avatar
Rewards Points: 428
Trouble shooting freezer...
Every time I read that, I think:
Proper grip, good sight picture, squeeze trigger.
Oso954 is online now   Reply With Quote
Old 08-04-2013, 06:51 PM   #5
Rewards Points: 280
Beat me too it!!! Not a good idea to do it in the house JIm
jjrbus is offline   Reply With Quote
Old 08-08-2013, 04:23 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
pretty easy to do. First find the tech manual, its usually located down behind the bottom grille somewhere. It will tell you how to force a defrost cycle, if it goes into the defrost then your board is bad(most likely) if it doesn't go into a defrost then ohm your heater and your defrost thermo. My experience tells me it will be the board, which runs about $125.00.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-08-2013, 08:20 PM   #7
Rewards Points: 22
Thank you! Unfortunately I lack the time to do the actual trouble shooting. I have a guy coming to look at it. Once he tells me what it is ill fix it myself. So I won't get totally hosed in the deal.
Old 08-12-2013, 05:19 PM   #8
Rewards Points: 22
Looks like it is the thermostat. $22 part. Now I just need to find it.
freezer outlet/lights issue racerguy Electrical 1 07-02-2011 02:31 AM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
