Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-10-2009, 10:58 PM   #1
Default Trouble with gas water heater pilot light
My pilot light keeps going out on my gas water heater. I re-light it just as described in the instructions - click the spark device several times while holding down the button, continue to hold down button for a full minute after flame appears, turn the gas knob back to ON, set the thermostat. And the light flames up big and stays lit for 10 to 20 minutes or so while it is heating the water to the level set on thermostat. But when it reaches that temp the pilot light goes all the way out (instead of just going back down to a small but still lit flame). I have repeated this process several times now with exact same results. Any ideas ? Or must i call a professional ?
Hotlantadave is offline   Reply With Quote
More On This Topic
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
So we’re back, and we’re going to show you guys how to get your propane gas grill lit safely and efficiently. We’ve already got our propane tank hooked up, so at this point I’m going to go ahead and show you, this is essentially a... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 12:02 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 01:08 AM
water pooling ontop of water heater nannerkrns Plumbing 2 09-24-2008 12:04 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 07:45 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
