Originally Posted by slickshift
Hmmm...it's an oil drain back issue huh?
Well, as long as it doesn't leak OUT I should be OK then huh?
Sounds like one side might be "better" than the other if it allows less drainage....I might have a look see before packing it up and try and figure which
Thanks for all the info
Yes and no. No leak that you will see. This is an enclosed system. Just let it sit long enough to make sure there is no oil in pressurized line going to the condensor coils. So yes, if you see no leaks and let it sit for a while, it should be fine. I reread your response and yes it is a drain back issue.
Another thing, make sure the drain pan is in correct position when you stand the fridge back up or you will get a wet floor. and maybe a hot compressor. The pan has to be placed in the correct position to catch the water that drains through the drain pipe in back of freezer. The fan blows on it and helps cool the compressor as it evaporates.
