Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-15-2012, 10:11 AM   #1
TP Valve discharge
One of my water heaters discharged water the other evening. The cold water coming in was then turned off. I turned it back on the next day. The TP has continued to drip water, though the water is not hot. Hot water runs from the sink.
My understanding is that it can be pressure, heat, or a bad valve. Since the dripping water was not hot, does that indicate a bad valve?
Hot water came out of the sink, while the valve continued to drip, suggesting it wasnt pressure, because running the hot water would reduce the pressure.
The dripping water isnt hot, which I am assuming means its not a temperature issue.
Is my logic correct? Any insight would be great, thank you.
Jerrys84 is offline   Reply With Quote
Old 10-15-2012, 10:37 AM   #2
TP Valve discharge
Sounds good, shut the water and heater off, drain some water out at the bottom and remove and replace the valve.
May want to try manualy lifting the trip lever a few times to see it it reseats it's self before replacing it.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
Gas valve on a bryant heavyduty HVAC 1 12-16-2009 09:42 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
