Top Rack Is Not Getting Any Water - Appliances - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 10:51 PM   #1
Top rack is not getting any water
I havew a frigidaire dishwasher that I bought about 2 yrs ago brand new. we had problems with the top rack not being clean and they replaced the main pump (under warranty). well, its doing it again. I decided to go at it myself and I noticed that the water supply for the top rack does not completely fill up - it has air in the top part of the tube. I also noticed that when it goes into top rack mode, it works for about 30 seconds then the water drain out and no more water goes to the top rack. Not sure why, but my guess is that the pump is not strong enough to supply the top rack with water - what does it sound like to you?
RPellecchia is offline   Reply With Quote
Old 10-24-2011, 08:42 AM   #2
Rewards Points: 472
a seal on the botton the tube ?? I don't belive the pump unless the peller is worn like a boat peller it is hard rubber ?? I would look for a seal i belive that is what would put air in the tube not the pump good luck
del schisler is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
