Top Loading Washer Serious Banging Brake?? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 05:41 PM   #1
Rewards Points: 93
Top Loading Washer serious banging brake??
I have a lower priced Kenmore top loading washer 4 years old. It developed a serious banging at the end of the spin cycle. The repairman was certain the brake was the problem. He replaced parts he felt would cure it. The problem remains. He and I still think it is the brake (no other issues with the machine...no bearing noise or oil leak).
However, the repairman has not experienced anything his action so far has not corrected, and is not very keen to start in any other repair as it may cost nearly as much as a new similar machine.
Three options....use it like it is until it flys apart (as it sounds it might) (nothing to lose but my hearing, correct?)
...dismantle it myself and try to remove noisy parts and just let it spin down without any brake (nothing to lose but my time and knuckles, correct?)
....get a new machine.
Advice on what to do?? Thanks, anyone.
Hossenfeffer is offline   Reply With Quote
Old 03-12-2013, 05:44 PM   #2
Rewards Points: 13,690
Model #?
Old 03-12-2013, 09:36 PM   #3
Rewards Points: 93
Kenmore 600 *
From Sears Canada
Thanks for asking.
*Also found model number 100-2967, 2968, or 2969 on the manual.
Old 03-13-2013, 08:29 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
is it one loud bang or more than that. if it is the brake it would only be one. The noise comes from the tub banging into the machine cabinet when the brake is applied. If he replaced the brake shoes and properly cleaned the liner then I really don't see how it would still be doing it. If you are getting more than one large bang then there is something else wrong
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 04:23 AM
Installation of Steam Front loading Washer and Dryer waldo43 Remodeling 1 05-25-2011 07:05 PM
maytag washer makes banging noise atechdrew Appliances 1 04-25-2011 08:38 PM
front loading washer LG or Amana twc Appliances 10 04-23-2011 05:10 AM
frigidaire front loading washer jim killen Appliances 1 01-05-2011 10:49 PM
