Top Load Washer Won't Agitate - Appliances - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 06:03 PM   #1
Top load washer won't agitate
I have a top load Maytag washing machine that doesn't go through the spin cycle.
It will agitate through an entire cycle, but once it gets to the spin cycle it won't spin or drain the water. Sometimes if I let it sit for a while, and put it on the last spin cycle it will work and drain the water.
Once the water's out, I can start a new cycle over, but like I said, it won't complete the cycle and stops at the spin cycle after the cool down and final rinse.
Also, at times when I put it on the last spin cycle after it has stopped working, it will start the spin cycle but it will eventually just stop working after about 10 seconds.
Thanks.
nuclearjesus is offline   Reply With Quote
Old 05-30-2010, 07:56 AM   #2
Rewards Points: 530
Hmm, sounds like maybe (maybe) the belt is stretching.. How old is it? Model and serial numbers?
If you replace the belt, get a belt made for the machine, not just any belt that fits.
I'm thinking older Maytags. I'm thinking the motor has to slide in order for different cycles to work. Remove the front and watch it as it changes cycles.
Also, check the that the pump spins freely.
Old 05-30-2010, 03:52 PM   #3
I replaced both belts about a month ago.
It worked perfectly until about a few days ago when my girlfriend said that it didn't drain. I removed the front panel and watched it. It agitates fine, but when it gets to the spin cycle it either doesn't work at all, or it starts to work and then shuts down. The motor starts to smoke after the spin cycle stops. I also noticed that when the spin cycle does go through ('cause sometimes it will engage), it doesn't spin fast like it usually does.
I'm thinking the motor just took a poop and is going to crap.
Also, a few hours ago I checked it again and tried to run the spin cycle. The motor started up, but the transmission didn't spin at all. It shut off after a few seconds and the motor started to smoke.
Not sure how to diagnose this.
Old 05-30-2010, 04:25 PM   #4
Rewards Points: 530
Not sure here either. The motor smoking does not bid well. Motor going bad or tranny or both maybe, I would guess.
The motor itself smokes, or is it the pulley smoking because the tranny is trying to lock up causing the belt to slip?
When you replaced the belts, did you get the belts specified for that washing machine?
Old 05-30-2010, 04:47 PM   #5
Rewards Points: 530
When you were watching this machine, did the motor reverse direction when it tried to spin?
I think you may have brake troubles that engage and disengage the hub and tranny. I have no experience with these to speak of. I do know the brake is under tension (2oolbs) and can cause harm to you if not properly removed with a brake wrench made for that purpose.
If it has plastic pulleys, you get lucky and have belts slipping on bad pullys.
LG Front load washer LarsFromMars Appliances 13 07-16-2013 11:04 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Front Load Washer handy man88 Appliances 3 07-01-2008 10:16 AM
Kenmore Top Load Washer gone Crazy ! kourso Appliances 1 07-09-2007 11:48 AM
