Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-08-2010, 12:39 PM   #1
Top load washer doesn't agitate but spins and drains the water
Can anybody help?
i have a Whirlpool YLTE6234DQ2 combo washer/dryer
for some reason the washer just stopped working. Put in a load and the water filled and then just stops...it doesn't do anything. Completely silent.
i tried Rinse cycle it doesn't work there either, but it does work in the spin cycle and drains the water.
makes no sense, since it spins i assume the motor is working. Since the water drains so the pump or hose doesn't look to be the issue.
can anybody help?
kowabunga is offline   Reply With Quote
Old 07-08-2010, 01:07 PM   #2
gmhammes's Avatar
try unplugging it for 10 minutes, it should reset however there should also be another way to reset it in the manual.
gmhammes is offline   Reply With Quote
Old 07-08-2010, 01:37 PM   #3
A few possible causes:
1. Bad sensor that tells when enough water has entered the tub.
2. Defect in motor causing one speed to not work, and different speeds are used for agitation and spinning.
3. Bad electrical contact in the timer so motor does not come on for that part of the cycle.
Does it work on the gentle fabric cycle or button selection?
Does it work if you set it up for a small load? (Do not actually run through the small load cycle with a large load of clothing; that will fray the clothing)
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 07-08-2010, 03:48 PM   #4
i have look for reset but i could not find it. i tried some resets from other manufactureres still doesnt' work.
Thanks for the help
Old 07-08-2010, 03:55 PM   #5
1. Bad sensor that tells when enough water has entered the tub. ( i assume sensor is working fine since it knows when too stop, tried small, medium large )
2. Defect in motor causing one speed to not work, and different speeds are used for agitation and spinning. (maybe? if the different speeds of the motor doesn't work it should still work on rinse cycle or at least try to move one way at least for a second? it just completely stops)
3. Bad electrical contact in the timer so motor does not come on for that part of the cycle. (this could be? i guess i'll need to call in technician)
Does it work on the gentle fabric cycle or button selection? - it doesn't work on fabric/delicate cycle. it does the same thing on all cycles.
Does it work if you set it up for a small load? (Do not actually run through the small load cycle with a large load of clothing; that will fray the clothing) - i have doen it with no load - something the care manual says when you do cleaning.. basically does the same with load. stopps after filing the tank. only way to after is put it spin cycle to drain the water.
Thanks for the help, looks like i'll need to bring a Techician for this. i was hoping to be able figure this out.
Old 07-08-2010, 04:41 PM   #6
gmhammes's Avatar
Thanks for the help
I know my motor reset is on the bottom of the motor however since it is working, not sure if that would help or not.
Old 07-09-2010, 08:29 AM   #7
Shadoglare's Avatar
I had a washer that acted similar a few years ago while I was renting - it filled with water and then just sat there. As the washer came with the rental I didn't have to personally deal with having it repaired, but I'm pretty sure when it was fixed the property manager said it ended up being the transmission?
Shadoglare is offline   Reply With Quote
Old 07-10-2010, 09:25 AM   #8
i assume it is the motor or the timer that defective now.. i have called in a technician to come in hopefully it won't cost me arm and leg..!!
sometimes if you can't fix it yourself it is better to get a unit.
if it is the transmission/motor then i think it might cost a lot to repair.
thanks everybody for you help and responses.
Old 03-09-2013, 01:24 PM   #9
checking and replacing the agitator dogs was the easiest and cheapest repair I've done to my washer machine. Completely fixed the problem. I followed this http://www.google.com/url?sa=t&rct=j...43287494,d.aWM
jdandar42 is offline   Reply With Quote
GE Profile Washer Model WPRE6100G0WT neither agitates nor spins tammy2006 Appliances 5 02-13-2010 02:33 PM
