Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-15-2011, 12:15 PM   #1
Top load GE Washer
My washer doesn't agitate or spin but fills and drains and it goes through a hole cycle. The motor runs through the cycle and turns off like normal. The belt is on and turns. If I grab the tub the agitater doesn't spin. What's the problem?
kesmiller is offline   Reply With Quote
Old 10-15-2011, 12:22 PM   #2
Experienced
Jackofall1's Avatar
Top load GE Washer
Hello kesmiller and welcome to the best darn DIY'r site on the web.
Your description is rather vague. Sounds to me like the timer is working correctly,
do you hear the motor running?
have you pulled away from the wall and removed the back to see if the belt is still on?
Mark
Old 10-15-2011, 07:13 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Top load GE Washer
sounds like the belt
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-15-2011, 07:39 PM   #4
Journeyman Wireman
Top load GE Washer
Bad motor coupling? Just replaced our last weekend. It was a Kenmore top load washer that wouldn't spin.
Here's the link to a Kenmore/Whirlpool video repair.
http://www.youtube.com/watch?v=MYB5x-IqtIM
I didn't find a link for a GE but you could search youtube.com for one.
Jupe Blue is offline   Reply With Quote
Old 10-15-2011, 08:31 PM   #5
#1 HAWKEYE FAN
Top load GE Washer
GE washers do not use couplers
Relocating washer standpipe 71Whaler Plumbing 3 09-23-2011 11:23 AM
Beware of Inappropriate Load Calculation Software - Source ACCA.org JJboy HVAC 5 09-06-2011 07:25 PM
Anana Front Load Washer Door Sagging horrocks Appliances 0 07-24-2011 06:29 PM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 11:14 AM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 12:13 PM
