-   -   titan tankless water heater (http://www.diychatroom.com/f47/titan-tankless-water-heater-81568/)
cewalls 09-16-2010 01:02 PM
the tankless water heater is model # n-120,220 volts,54 amps. I hoked it up but keept blowing the fuse I heard I would have to run 2 elec lines to the panel is this true?
NoHax 09-16-2010 03:49 PM
I found the answer to your question via the internet in about 20 seconds. I also presume that you probably purchased this device "used", and an installation manual was NOT included with the heater.
The wiring from your breaker panel to this new device requires immediate attention. If you don't follow the wiring instructions for this device, you risk burning down you house.
  1. What size breaker are you using for this device?
  2. What size wiring circuit is going to this device?
  3. Have you determined if your main breaker panel can handle the extra load from this device?
  4. Did you install a new, dedicated circuit to this device, or did you splice into some other circuit?
Good luck!
