Timer Won't Stop - Appliances - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 12:17 PM   #1
Unhappy
Timer Won't Stop
Spoke to Soon
I just thought i had it fixed. As I said in the original post
Kenmore Dryer Keeps burning up the fuse
"the dial does not stop at the end of the cycle it continues to turn, seems like until it gets back to straight up at the top."
We usually run it in the timed section. An example of the problem would be if you had started the dryer at 50 minutes and opened the door at 20 and removed the clothes then shut the door without restarting the dryer. The heater coil continues to stay hot while the door is open or closed until the timer reaches zero. Then the timer continues to click all the way back around to just before the timed section starts.
Does the timer need to be replaced or is there something causing the timer to do this?
Again I appreciate any help
jones6826 is offline   Reply With Quote
Old 04-09-2013, 01:26 PM   #2
Rewards Points: 744
Check this out:
http://www.applianceblog.com/mainfor...-shut-off.html
Seattle2k is offline   Reply With Quote
Old 04-09-2013, 01:58 PM   #3
Sounds like I need a timer. Is there a place I could buy one from that would let me return it if it doesn't fix the problem like it states in this post?
Kenmore Model # 110.67522600
Old 04-09-2013, 02:43 PM   #4
Rewards Points: 744
http://www.appliancepartspros.com/
http://www.repairclinic.com/
Both of them have 365 day return policies.
Old 04-18-2013, 04:21 PM   #5
Rewards Points: 744
So, did you get it fixed?
Old 04-18-2013, 08:14 PM   #6
Yes I did, the timer did it.
Thanks for ur help
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
how to remove timer box for hallway lights at apartment building mikael6 Electrical 3 01-16-2013 08:31 AM
GE 15312 Timer installation tbdbitl Electrical 1 12-13-2012 03:40 PM
Help with Pool Timer Intermatic P1353ME TGMcCallie Electrical 4 08-03-2012 07:44 PM
Wall Timer Wiring Issue sjh5g Electrical 18 02-16-2012 10:57 AM
