#1 |
thermocouple for whirlpool
i have a whirlpool gas water heater and the thermocouple has gone bad so i purchased a new one from lowes and i can not get it to screw back into the main controll unit....the old one will screw in so i know the threads are ok....so i purchased another one and that one will now screw in either.....what could i be doing wrong
#2 |
Sometimes they are very tough to screw in, have to be very straight with it or it won't work.
It's also possible you bought a thermocouple with a different thread. |
#3 |
You probably have a left handed thermocouple (either the new one or the old one). Screw your old one back in to to the gas valve to find out, or compare the threads.
#4 | |
Special User
thermocouple for whirlpoolQuote:
I was able to purchase a kit that replaced the entire front panel of the burner assembly. The new front panel has a high limit switch in the panel, instead of in the thermocouple, so you can use a standard thermocouple. The kit comes with wires and a thread adapter so you can wire the new panel-mounted limit switch to the thermocouple thread adapter. |
| Display Modes | |
| Need help with thermocouple replacement on MC furnace | YerDugliness | HVAC | 8 | 01-13-2012 08:24 PM |
| Thermocouple nut problem w/ gas fireplace | movick724 | Appliances | 1 | 11-08-2011 04:00 AM |
| Thermocouple and Gas Valve | dimjim | HVAC | 10 | 03-22-2011 11:05 PM |
| How long for the thermocouple to shut off the gas? | dashworth | HVAC | 4 | 10-29-2010 09:41 PM |
| Resource for understanding gas valve? | darsunt | HVAC | 19 | 02-04-2009 12:08 AM |
