Thermocouple Nut Problem W/ Gas Fireplace - Appliances - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 01:51 AM   #1
Thermocouple nut problem w/ gas fireplace
Hello,
I have a Superior brand LP gas fireplace model DR 600 CMP (Honeywell valve assy.) which has a shot thermocouple (see linked image top left). Apparently the thermocouple split/exploded or what have you and needs to be changed out. I called my local supplier and have a new one on order.
I attempted to loosen the retainer nut (arrowed in linked image) by turning it clockwise (from above) with a ˝” open wrench. The thing is so tight that the whole pilot assembly is twisting as I apply torque to loosen the nut. There is nothing to grab on the assembly itself to prevent this problem and I’m at a loss. I did try grabbing a portion of the assembly between the thermocouple and the pilot (in the front) with a pair of needle-nosed Vice Grips, but it didn’t help much.
Can anyone suggest what I can do to loosen that nut so I can replace the thermocouple?
Thanks in advance!!
Movick
movick724 is offline   Reply With Quote
Old 11-08-2011, 03:00 AM   #2
Penetrating oil like Kroil perhaps? I'm just afraid that overspray may contaminate the delicate parts of the assy. I'll of course mask off all critical areas. Yes?
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 07:54 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
