Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-22-2012, 02:27 PM   #1
Thermador oven going nuts
My Thermador CM302 oven warms up and then, sometimes shuts itself off and starts beeping repeatedly until I hit the touchpad a few times or open and close the oven. It will sometimes start working again and sometimes not.
I think I've isolated the problem to one of two ovens, the top one. The lower oven doesn't seem to cause the problem, though it's intermittent, so I'm not absolutely sure.
About a month ago the element burned up in the lower oven (quite a light show). I replaced it and it is fine now. I'm wondering if the upper element might be shorting out or something and need replacement, too, since they're both the same age (though I suspect the upper has seen more use). Could that cause the problem I'm having? I don't get any error message on the readout.
cbuck1 is offline   Reply With Quote
Tags
beep, oven, thermador
Can you use wire nuts on a fan light switch with silvery looking wires? amodoko Electrical 4 10-28-2012 09:26 PM
Replace wire nuts? PPBART Electrical 7 10-07-2012 12:28 PM
How to fasten heater element nuts under dishwasher? darsunt Appliances 0 12-04-2009 12:21 AM
Impact gun not removing lug nuts n0c7 Tools 10 06-18-2008 04:20 AM
hold the nuts! (wire nuts that is) analogmusicman Electrical 6 05-25-2008 12:34 PM
