Is There A Way To Test Refrigerator Water Filter? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-12-2016, 09:38 PM   #1
Rewards Points: 45
Is there a way to test refrigerator water filter?
I have a Whirlpool GD25DFXFW01 side by side refrigerator. The water dispenser and ice maker have stopped working. I don't know if the water filter can get clogged enough to cause this. My water filter is a long one that mounts into the grill at the base of the refrigerator. The model number of the filter is 4396508. Is there some way to inspect the filter to see if it is causing the problem? Thanks.
rvmeush is offline   Reply With Quote
Old 03-13-2016, 12:43 AM   #2
Re: Is there a way to test refrigerator water filter?
Most refrigerators will work with and without the filter. Try it without the filter and see what it does
BayouRunner is offline   Reply With Quote
Old 03-13-2016, 07:57 AM   #3
Rewards Points: 13,450
I'd start by seeing if your even getting any water to the filter.
If someone used a saddle valve where it connects to the main line it's common to have the valve plug up and leak, there against code in some areas because of the issues.
https://www.buydirectwaterfilters.co...g-saddle-valve
If you have the model # you can check out repairclinic.com for a list of items that can cause this and the steps to take to figure it out.
Colbyt (03-13-2016)
Old 03-13-2016, 08:00 AM   #4
The filters to eventually plug up and need to be replaced. If you can't remember the last time it was replaced its time .
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
SeniorSitizen (03-13-2016)
Refrigerator ice maker and bypassing of filter mrivney Appliances 11 04-08-2015 09:59 AM
small engine fuel filter recommendations gunner666 Landscaping & Lawn Care 2 07-30-2014 10:17 PM
Input and output hvac Duct too small LiL-Daddy HVAC 9 07-10-2014 05:40 PM
Furnace Filter Question turtlegrrl HVAC 8 08-04-2012 07:04 PM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
