-   -   are there range hoods that do not require electrical hookup? (http://www.diychatroom.com/f47/there-range-hoods-do-not-require-electrical-hookup-132964/)
Barb C 02-07-2012 09:24 PM
i have no electrical to connect a range hood under my cabinet. are there any range hoods on the market to just look good, and perhaps catch the smoke and grease. . . but do not need electrical?
joecaption 02-07-2012 09:29 PM
No, just have someone run a line to it, done all the time. No harder then adding an outlet.
ratherbefishing 02-10-2012 11:19 AM
Is your range gas or electric? A lot of new gas ranges have an outlet behind them for the ignitor. Dropping a wire straight down the stud bay isn't that hard.
user1007 02-10-2012 12:09 PM
No is the easy answer. You probably have a dishwasher and disposal? You will have easy access to 110v needed for a fan hood there you can tap without too much trouble if you have a tiled backsplash or something you do not want to break up. It is nice to keep a dishwasher with heating element on its own circuit though.
Your ceiling fixtures are likely wired hot, with a switch in the middle, so you could tap that circuit for a low watt hood fan unless there is a bunch of stuff on it.
You do have a plan in mind for venting the hood right? Make sure you get a good one with accessible grease filters and so forth. Last thing you want is a new stove exhaust hood sucking stuff and grease and depositing it in the attack or ceiling space! Have seen DIYers do this more times than I would like!
Yoyizit 02-10-2012 03:51 PM
Search on
battery range hood
Smoke and grease are heavier than air so I can't see how this could work without a fan. Convection won't do it and a positive pressure in your house might scatter the smoke and grease everywhere.
Can you run a duct to where there is power available?
dipika4564 03-15-2012 11:23 AM
Range Hoods
Hi everyone, Gas or Electrical range hoods both are advantage and disadvantage. before try one please must see the features.
troubleseeker 03-16-2012 10:04 PM
[quote=sdsester;849615]No is the easy answer. You probably have a dishwasher and disposal? You will have easy access to 110v needed for a fan hood there you can tap without too much trouble quote]
That is against code. Each permanent appliance ; dishwasher, range, refrigerator, built in microwave, etc. is required to have a dedicated circuit. Are these kind of taps commonly done, yes; but that doesn't make them correct.
