Is There A Quick Fix For A Malfunctioning Gas Water Heater? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-26-2007, 01:08 PM   #1
Is there a quick fix for a malfunctioning gas water heater?
My gas water heater recently took a nose dive. The pilot light had gone out again,after being relit maybe a week prior. Now it's out again. The pilot light will light but when i start to turn the dial to the on position the pilot light goes out and the burner will not ignite.im pretty familiar with thermostats and how they work in general, but I was wondering if there was a way to somehow allow the gas to go through the thermostat into the burner by removing the rubber backed stopper and therefore eliminating the need for the temp sensetive wire that tells the thermostat to open up.. I took the thermostat apart and it seems like if i remove the spring loaded stopper, it would allow the gas to get through into the tank making sure to shut off the gas valve after Im done using the hot water....will this work?
Nate is offline   Reply With Quote
Old 05-27-2007, 01:04 PM   #2
Rewards Points: 77
Why not replace the thermal couple sp? that sounds like your problem. That's the wire thingy. I've replaced them on water heaters and wall furnaces they do go bad. Unless you know what your doing with the thermostat I wouldn't and if your asking here you probably don't.
Zero Punch is offline   Reply With Quote
Old 05-27-2007, 09:15 PM   #3
Diesel Fitter
Rewards Points: 150
Don't remove anything.Replace the thermocouple if you can. If you try to rigg that valve you'll die. 1 more thing, if you took the valve apart go get a new water heater or ......You'll die.
mikemy6 is offline   Reply With Quote
Old 05-28-2007, 05:12 PM   #4
Rewards Points: 6,652
Because we all know that it is cooler watching a flame thrower burn the building down (try explaining that one to the Insurance adjuster), then fixing the problem in the first place.
I am sorry, but if someone is speaking out loud about doing something that is not safe, it is time to call in the professionals.
Old 05-30-2007, 10:21 AM   #5
Rewards Points: 530
Whew! This is a scarey post! I would have tired to maybe clean or better yet, replace the coupling and checked to make sure the venting was not blocked. Thermal coupling do indeed go bad. There are also safety features that will not allow operation if the venting becomes obstructed. Do not try to do any rigging or bypassing with gas! Better to be in cold water than cold ground! Think of your family and your home.
The Following User Says Thank You to boman47k For This Useful Post:
jimn01 (10-30-2015)
Old 10-30-2015, 05:52 AM   #6
Rewards Points: 46
Gas water heaters are less efficient than electric heaters, but electricity is much more expensive.
The tank should be firmly affixed to a structure such as the wall in earthquake prone areas to prevent a potential gas fire if the tank falls over and breaks the gas connection.
carneywatson001 is offline   Reply With Quote
Old 10-30-2015, 06:19 AM   #7
Originally Posted by carneywatson001
Gas water heaters are less efficient than electric heaters, but electricity is much more expensive. The tank should be firmly affixed to a structure such as the wall in earthquake prone areas to prevent a potential gas fire if the tank falls over and breaks the gas connection.
And this has what to do the original post?
jimn01 is offline   Reply With Quote
Old 10-30-2015, 06:21 AM   #8
The quick fix is to fix it properly. And that means replacing the thermocouple and whatever other parts that may be faulty. Please, what you propose is dangerous.
Old 10-30-2015, 06:25 AM   #9
An old Tradesmen
Rewards Points: 6,576
Who knows. Maybe the OP burned his house down 8 years ago just after he made this thread. He never came back after making the original post at 1:08 PM 5-26-2007
The Following 2 Users Say Thank You to beenthere For This Useful Post:
danpik (10-30-2015), Tom738 (10-30-2015)
Old 10-30-2015, 07:02 AM   #10
Oops my apologies for not looking at the original date and for contributing to the resurrection of a zombie thread.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
