Tappan Stove Help Needed - Appliances - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 11:14 PM   #1
tappan stove help needed
tappan stove gas, electronic igniton. model number 303152 23/02
all top burners work, when trying to start the oven, only the glow plug will light, burners dont ignite, any ideas what to check or replace.?
tecate1987 is offline   Reply With Quote
Old 06-04-2009, 10:33 AM   #2
Check the timer control and make sure the oven is not in the automatic cleaning cycle. Following that, you’ll want to check the common wiring, selector switch, and thermostat. Make sure the controls and selector switches are set correctly. If the range control reads push for manual, push the knob in and try your oven and broiler again. If this doesn’t help, you probably have a faulty selector switch, thermostat, thermocouple, or a wiring problem.
If there is no separate selector switch for bake or broil, most often the problem is the thermostat. There’s not really an easy way to test the selector switch, so if you think there’s a problem with this, you should call a professional appliance repair person. The thermostat should read 0 ohms when in the on position.
For more help go to AP Wagner Appliance Parts
jronimo is offline   Reply With Quote
Old 06-05-2009, 03:59 PM   #3
HVAC / Plumbing
Those oven valves also open on amps .. Weak ignitor = gas valve won't open... Iginitor can be weak & still glow
kenmac is offline   Reply With Quote
Aurora wood stove info needed. jehiatt General DIY Discussions 11 01-18-2012 09:35 AM
3 wire stove connection bgoldie Electrical 13 03-01-2011 01:29 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
