Switching Off Gas Fire - Appliances - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 06:39 PM   #1
switching off gas fire
just moved in no manual put on gas fire by pushing up lever now i want to switch off assumed you would just lower lever but no i cant switch off help
redscot21@gmail is offline   Reply With Quote
Old 03-28-2013, 07:47 PM   #2
Rewards Points: 1,668
If you are still alive enough to read this get out of the house and call the fire department.
SeniorSitizen is offline   Reply With Quote
Old 03-28-2013, 08:53 PM   #3
First, if you smell a lot of gas, get out and call the FD.
If not, There should be a shut off valve on the feed line. Loof for a small copper tube coming in from behind or under the fireplace. Follow it until you find a valve. The valve should turn perpendicular with the copper line. That is off.
Stcrosby is offline   Reply With Quote
Old 03-30-2013, 06:21 PM   #4
Rewards Points: 83
Most likely just have to push the knob in and turn at same time to shut off.
Protocol. is offline   Reply With Quote
Old 03-31-2013, 05:33 PM   #5
pictures are most helpful
Gulf Island Building. cocobolo Project Showcase 8228 11-17-2015 02:02 AM
Concrete Fire Pit Project - Advice polizei11 Concrete, Stone & Masonry 2 11-13-2012 02:34 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
