Surge Protector That Delays Power To Certain Plugs? - Appliances - DIY Chatroom Home Improvement Forum
Old 06-23-2008, 11:10 PM   #1
Surge protector that delays power to certain plugs?
I am looking for a surge protector or strip outlet that has plug ins that are timed/delayed.
I would love to have 'normal' plugs and one or more delayed plugs which could possibly delay the power 2 minutes before switching on.
Any ideas?
Thresher is offline   Reply With Quote
Old 06-24-2008, 06:46 AM   #2
You aren't likely to find anything like this commercially available, but you could build your own fairly easily. It would just require a "time-delay-relay", which are fairly expensive. Here's a link to some surplus ones:
http://www.surplussales.com/Relays/RETimeD-2.html
Scroll down about 3-quarters of the page to find part #W211ACPSOX8 @ $39.
You would need to build an outlet box with a switch. The switch would activate your first couple of outlets and the relay. The relay would activate your "time-delay" outlets. Fairly straightforward, but you would need a bit of electronics/electrical know-how.
Good luck.
Artie2 is offline   Reply With Quote
Old 06-24-2008, 12:15 PM   #3
Thanks Artie I will follow up on this and see what can be done.
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 02:33 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
