Sunbeam Window Air Conditioner - Appliances - DIY Chatroom Home Improvement Forum
Old 07-03-2009, 01:14 PM   #1
Sunbeam window air conditioner
I have a Sunbeam window air conditioner that will not drain the condensed water out of it. It drains inside on the wall. So I guess the drain plug is clogged. But does anyone know where that would be located? And if you do how do I unclog it? I have had to take the front panel off and get the water out with a turkey baster. If I don't it drips on my floor. Help!!!!!!!!!!
lazydaize23 is offline   Reply With Quote
Old 07-03-2009, 05:55 PM   #2
The A/C is supposed to have a slight pitch so the water goes outside.
The drain opening should be easy to find. Use a coat hanger wire to unclog. You might be able to do this without taking off the A/C housing.
I think that some units don't use a drain, they somehow evaporate the condensate fast enough to keep up. These units are supposed to be level.
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Installing window air conditioner mary60 Electrical 1 08-14-2008 06:25 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 11:50 AM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 03:24 PM
Window air conditioner pwallyp Electrical 3 03-10-2007 10:04 AM
