Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-26-2012, 03:55 PM   #1
stove top and drop in oven
have a stove with 6g power supply to and want to change to stove top and separate oven with each having 12g. How to connect with existing power.
Linda J is offline   Reply With Quote
Old 05-26-2012, 04:40 PM   #2
MarginallyQualified
The 6ga wire at the range is good for 60Amps
The wall oven and the cooktop however are likely to need more that 12ga (20Amp)
Check the appliances and the literature.
To answer the question... the new appliances and new locations will need new wire pulled; use wire of the correct size/type and # of conductors.
TarheelTerp is online now   Reply With Quote
