Stove Top - Appliances - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 10:59 AM   #1
stove top
what size of breaker should i use
mcculla is offline   Reply With Quote
Old 12-02-2010, 12:05 PM   #2
Rewards Points: 256
Breakers should be sized to wiring, not the appliance.
To answer the question use the correct size breaker for the size wiring you need.
You would have better luck posting this in the electrical section.
50amp should work for any electric stove. Many could get by with less. Look at the owner's manual. To see what it needs.
Most people reccomend only using 80% of the circuit's capacity.
michaelcherr is offline   Reply With Quote
Old 12-02-2010, 09:08 PM   #3
Rewards Points: 150
I agree. Check the back of the appliance where the model number is written. The number of amp needed is also indicated there. Post this on the electrical section to get clearer explanation from experts over there.
MagicalHome is offline   Reply With Quote
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 11:04 AM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
