Stove Conversion - Appliances - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 07:34 PM   #1
Stove conversion
How do we replace our electric range with a gas range
cstanzel is offline   Reply With Quote
Old 05-19-2011, 08:01 PM   #2
Learning by Doing
Leah Frances's Avatar
unless you want the answer 'buy a gas one' you should ask a more specific question. Give us some details. Help us, help you.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-19-2011, 09:54 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
buy a gas one.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-21-2011, 09:15 PM   #4
Ironlight's Avatar
You have two choices, natural gas or propane, depending on if your house is served by natural gas or not. The stoves use different types of manifolds to accommodate the different properties of the two types of gas and service.
Buy a natural gas range if your house has natural gas service. If there is natural gas in your neighborhood but your house is not (as far as you know) piped for it, call your gas utility and inquire about connecting your house to the gas main. You would then need to hire a plumber to run the interior gas line to the location for your stove.
If you don't live in an area with natural gas service you can get a propane tank that sits outside your house and a propane stove. You would need to have the tank professionally installed and piping run to the range location.
Oh, then go out and buy a gas stove
Ironlight is offline   Reply With Quote
stove conversion ayden12 Appliances 4 03-28-2011 10:10 PM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
Natural Gas to L.P conversion on stove. RobertS Appliances 4 03-10-2008 01:06 PM
Gas stove top/oven conversion to combo range... Leikela Appliances 1 03-08-2007 07:16 PM
