Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-30-2012, 07:33 PM   #1
Post
Start relay problem?
I have an Admiral ASD2514ARW (series 11) refrigerator that stopped working after the freezer door was left open all night (Thanks to my lovely bride... lol). I believe the problem is the start relay or the overload, but I cannot get the terminal cover off. I am afraid of pulling/prying too hard and risking bending one of the connectors on the compressor. Is their a trick to getting it off? The terminal cover part number is 61002138 and pictures are attached.
Also, should I replace both the start relay and the overload?
rnelson is offline   Reply With Quote
Old 01-30-2012, 08:31 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
insert flat blade screwdriver under that bottom tab and pop it off.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-30-2012, 08:44 PM   #3
#1 HAWKEYE FAN
what makes you think it is the realy/overload?
Old 01-30-2012, 09:10 PM   #4
The screwdriver worked. The compressor was clicking on and off. The relay is off of the compressor and it rattles. Cam I check it with a multimeter?
Old 01-30-2012, 11:23 PM   #5
#1 HAWKEYE FAN
if the relay is clicking and compressor not starting then it is probably bad, just buy a new one and try it.
Tags
compressor, overload, refrigerator, start relay
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Bryant Plus 90 start up problem mgraw HVAC 2 01-07-2008 06:54 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
