Stain On Toaster Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2015, 05:12 PM   #1
Solidify's Avatar
Rewards Points: 780
Stain on Toaster Oven
Someone left a bag of toast bread on the toaster oven while they heated up a meal, the result being that the paint from the bread bag heated up and stained the top of the oven.
I tried heating the oven and scrapping it off to no avail. Is my option to paint over the stain?
Stain on Toaster Oven-imageuploadedbydiy-chat1424124720.821304.jpgStain on Toaster Oven-imageuploadedbydiy-chat1424124732.102117.jpgStain on Toaster Oven-imageuploadedbydiy-chat1424124741.093705.jpg
Solidify is offline   Reply With Quote
Old 02-16-2015, 05:22 PM   #2
Rewards Points: 6,652
Just leave. Adds character.
Old 02-16-2015, 05:28 PM   #3
Rewards Points: 12,812
Make whoever left that bag there buy you a new oven.
As cheap as they are it's not worth sanding priming and paint with high temp. paint.
Old 02-16-2015, 05:35 PM   #4
Rewards Points: 408
Of the thousands of decorative trivets available I'm sure there is one suitable to cover that mistake.
Old 02-16-2015, 05:54 PM   #5
Solidify's Avatar
Rewards Points: 780
Can you suggest me one?
Old 02-16-2015, 06:18 PM   #6
Rewards Points: 408
You want an old man on the farm to suggest interior decorating? Possibly google, ebay, wallmart or some local fancy interior decorating shop would have some ideas.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
gregzoll (02-16-2015)
Old 02-17-2015, 08:48 AM   #7
Solidify's Avatar
Rewards Points: 780
Sorry, I had no idea you were "an old man on the farm." I just thought since you brought up the idea, suggesting there are plenty of ways, that naturally you'd have one in mind. But that's OK, I see your point.
Old 02-17-2015, 09:15 AM   #8
Rewards Points: 83
Magic eraser? That stuff works wonders. Otherwise you could secure a small sheet pan/baking pan to the top of it.
Protocol. is offline   Reply With Quote
Old 02-17-2015, 11:36 AM   #9
Rewards Points: 408
and OH how the internet can sometimes be entertaining. and I do truly apologize for attempting to keep my first reply so short. I wish you well in your search.
Old 02-17-2015, 12:55 PM   #10
Knows Enough to be Danger
Rewards Points: 701
Have you tried the magic eraser or barkeepers friend route? I don't know if they'd work on a burnt in type stain, but it'd be worth a shot?
NickTheGreat is offline   Reply With Quote
Old 02-17-2015, 02:43 PM   #11
Rewards Points: 347
Here's how I would attack the problem:
1. Try using a variety of solvents starting with nail polish remover, turpentine, WD40, gun cleaning solvent (bore solvent will degrade plastic fast) choke cleaner, etc. Put some on a cloth and let soak on stain overnight to soften the plastic residue.
2. Then try emery cloth or jewelers cloth but NOT sandpaper.
3. Next a vibrating sander with the finest grade of paper possible.
4. Still no luck, then sand and paint.
5. If that looks hideous then cover or pitch.
DanS26 is online now   Reply With Quote
Old 02-17-2015, 02:52 PM   #12
Solidify's Avatar
Rewards Points: 780
Nick, the magic eraser did not work. Good try though.
Dan, I'll post back my results.
Old 02-17-2015, 03:12 PM   #13
Rewards Points: 222
I think Goo Gone or Goof Off might work. They work really well to remove sticker residue. You can get them at Wal-Mart and most other major retailers and home improvement stores.
LeakyHawaiiRoof is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
What's the best TOASTER OVEN for general use and ocasional pizza. CrimsonAMV Appliances 12 10-17-2013 08:54 AM
Whats the best toaster oven? Squeakyhinge Appliances 1 03-17-2013 05:57 PM
Is it ok to use this connector in a toaster oven? mikegp Appliances 6 11-13-2012 12:10 AM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
