Stacking Washer And Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 03-13-2008, 10:06 PM   #1
Rewards Points: 150
Stacking washer and dryer
We already have a small Kenmore washer and we just bought a small dryer of a different make. (i forgot the brand) Salespeople have told us you can not stack different makes toghether. I am sure that is not true.
Does anyone have some ideas of something i could "rig up."
Tahnks, this is a great site.
Cossack is offline   Reply With Quote
Old 03-14-2008, 01:33 PM   #2
Different manufactures have different was of mounting the dryer on the washer so the sales person could be right.
The only thing that may save you is your Kenmore washer may be manufactured by the same company as the dryer.
What is the model number of your washer? The model number will have three number and then another six to eight number. The first three will tell me the manufacture of your washer.
What is the brand name of your dryer?
girltech is offline   Reply With Quote
Old 03-14-2008, 08:12 PM   #3
Rewards Points: 150
I am sure that since the washer and dryer are two different makes there is no pre-made bracket I can use, but I am sure that does not mean it can not be done.
I am wondering if I should build a shelf above the washer to hold the dryer or rig some kind of L-brackets to the washer top and attach the dryer with those.
Old 03-17-2008, 12:31 PM   #4
Sure you can build a shelf over your washer that will hold the dryer.
What I was saying about the Kenmore is that Sears does not make any of there appliances.
Some of there appliances are made by GE,some are made by Frigidaire and some are made by Whirlpool.
So if your dryer is a Whirlpool and the model number of your washer start with 110 the mounting kit for the Whirlpool would work with the washer because they are made by the same company.
If your dryer is a Frigidaire and the washer model number start with 417 the mounting kit will work.
The same would apply with the GE if the washer model started with 362.
Or you can make your own bracket.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Recommendations on Front Loaders Washer/ Dryer helpless handyman Appliances 6 02-15-2008 11:59 AM
Moved Washer, Dryer and Laundry Tub chaz Plumbing 4 11-03-2007 03:35 PM
Installing a stackable washer dryer in hall closet next to bathroom uncleb23 Plumbing 2 10-04-2007 08:51 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
