Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-30-2012, 10:01 PM   #1
Stacked Washer/Dryer Accessibility
Hello,
I am wondering if anyone has seen or done a sliding tray or other method to move a stacked washer and dryer in and out in case the units have to be serviced. I have not installed them yet, and would like to be able to move them in and out without a lot of effort in the future should trouble arise. Thank you in advance....
timmay5309 is offline   Reply With Quote
Old 12-30-2012, 11:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
sounds like a good idea, but... I see two problems. 1) you will not be able to make a heavy enough sliding tray to support a stack unit, you will have vibration and walking issues. 2) Vent issues, how will you hook up the exhaust vent for the dryer ?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-31-2012, 12:12 AM   #3
That is what I was thinking of too... I was hoping someone had a clever idea or had seen anything like that. The best idea so far to me is to keep the one side panel available for the option to open up. Walking the unit back slowly, then having the side panel off will help with making sure the hookups are not pinched.
Tags
stacked washer dryer
Stack washer/dryer: why do both start simultaneously? kylan Appliances 4 10-06-2011 09:43 PM
Adding a washer/dryer to existing washer/dryer setup oper573 Plumbing 1 01-30-2011 10:48 AM
Moving washer/dryer, etc. ClnlBrahm Plumbing 17 12-29-2010 09:47 PM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 05:00 PM
How to handle circuit for washer/dryer relocation? KUIPORNG Electrical 9 06-16-2006 10:09 AM
