Stackable Washer Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 09:08 PM   #1
stackable washer dryer
I would like to get a stackable washer/dryer for my apartmant. Am I able to use the regular outlet for power? Also what should i do about the water draining from the washer.
juliebooker49 is offline   Reply With Quote
Old 12-17-2010, 11:29 PM   #2
Yes, you are able to use the same power outlet only if your getting a 110 outlet for an 110 appliance meaning (gas dryer, and regular size washer). Now if your going all electric then it must be a 220 source. For your drain, USE the existing one if there is one or if you are close to a drain or sink or somewhere you can put the water then you should be set to go.
unlappliance is offline   Reply With Quote
Old 12-18-2010, 12:14 AM   #3
There are dryers out there that work on 110v. I had an Asko condensing dryer in an apartment a few years which ran on 110v. While it didn't work as well (it didn't dry as large of a loads that a 220v model can) it served me well enough.
VIPlumber is offline   Reply With Quote
Old 12-19-2010, 01:05 AM   #4
Registered User
Rewards Points: 4,924
Check with your landlord or manager if adding appliances or moving the location.......
Gary
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Stackable washer and Dryer in hall closet thatannegirl General DIY Discussions 7 11-06-2009 06:22 AM
Stackable Washer / Dryer Upstairs RammsteinNicCage Appliances 5 04-30-2009 06:23 PM
Installing a stackable washer dryer in hall closet next to bathroom uncleb23 Plumbing 2 10-04-2007 08:51 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
