Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-19-2010, 01:43 PM   #1
Squeaky washing machine
I have a wonderful Maytag washer, bought in 1971, used ever since. No problems whatsoever - till now. It has developed a LOUD squeak, almost a groan. I don't know anything about washers, but the sound makes me want to go pour in a quart of oil (just kidding) or use WD40, as for other things that squeak. Can anyone suggest what to do, or check, before I call a lonely Maytag repairman?
Thanks!
sydneymath is offline   Reply With Quote
Old 01-19-2010, 01:55 PM   #2
Question
Thanks!
BTW: that original, "lonely" repairman has passed on to the world of eternity.: As for the "squeak, I was inclined to say that the washer/dryer is out of balance. But you say that it is a recently developed problem. Could be a loose or worn belt engaging the pulley at the wrong angle???
spark plug is offline   Reply With Quote
Old 01-19-2010, 02:10 PM   #3
And may God rest his little soul. I'm sure you're right about that.
As for now - yes, sounds like the belt probably needs replacing. It'll be the first thing to check.
Many thanks!! I'll post a follow-up!
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
