Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-07-2008, 09:45 AM   #1
weekend warrior
Hobb3s's Avatar
Squeaking Oven
This may sound odd. We have an older electric oven that came with the house we bought. It still works perfectly, except for when the oven has been on for a bit. Then it starts squeaking, an intermittent (like once every 20-30 seconds) kind of squeak. It sounds like a metal on metal kind of squeak.
Anyone ever experienced this? We can reproduce it every time, but I've not been able to localize the noise.
Any suggestions?
Hobb3s is offline   Reply With Quote
Old 05-07-2008, 01:15 PM   #2
jeff1's Avatar
Squeaking Oven
Hi,
Oven
Built in oven, oven part of a range?
Make, model#?
Oil canning is common, but that -usually- produces a bang like noise.
Metal expanding or contracting ( liner, racks, element ), cooling fan, clock, control probe moving ( if used ), hinges, door liner...
Lots of oil canning problems, lots of door hinges squeeking when the door is opened and closed once the oven is hot.
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 05-07-2008, 02:42 PM   #3
weekend warrior
Hobb3s's Avatar
Squeaking Oven
Make, model#?
Oven part of a range.
Make is GE I think, model, I'm not sure, I'll have to search for a sticker.
Oil canning, I'm not familiar with that term. But it's definitely not a bang. I'll have to look up what that means. (just looked it up, learned something).
Yeah, it's definitely not from opening the oven door either, we'll be sitting in the living room and hearing the squeaking.
Old 05-07-2008, 05:04 PM   #4
jeff1's Avatar
Squeaking Oven
Hope it's not a mouse getting too hot
Great
jeff.
JRAppliance
Old 05-08-2008, 12:59 PM   #5
Squeaking Oven
You should be able to find the model number on a tag on the frame of the range where the drawer closes.
The oil canning is usually just when the oven is first heating up and when it cools down.
Does the range have an electronic clock control or an analog clock?
girltech is offline   Reply With Quote
Old 05-08-2008, 02:03 PM   #6
weekend warrior
Hobb3s's Avatar
Squeaking Oven
I'll look there. I took a quick look last night and realized it's a Kenmore not a GE. (different appliance).
Didn't find a sticker, but I'll check where the drawer closes.
It's has an analog clock (Iit's not a clock face, but numbers that turn like an odometer).
Yeah, it usually happens after it's warmed up all the way after stuff has been in for 5 minutes.
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Wall oven smaller than Cabinet Space kdiangson Appliances 4 11-13-2007 10:21 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
Wall oven rusty_5620 Electrical 6 03-15-2007 02:18 AM
Is my oven a dodgy shape? SiBG Appliances 2 09-25-2006 08:15 PM
