Squeaking Dryer - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 11:56 AM   #16
Loose pulleys where the belts are can cause squeeks a lot of times. Sometimes, it's the belts themselves that causes it especially if it is on that age.,
You can try cleaning first the belts or replace it or you can also seek for loose pulleys from the motor or the center drum. They usually have a lock and if you tighten it, that usually cures the problem.
masterofthe is offline   Reply With Quote
Old 08-02-2008, 12:40 PM   #17
Rewards Points: 150
The repair kit I bought fixed the problem. The only belt-related pulley on this dryer, FYI, is the motor itself. The tensioner is more of a guide on a piece of metal, it doesn't have a rotating assembly on it at all.
Either way, the dryer if fixed and all is good.
curls00 is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 01:26 PM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 04:33 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
