Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-12-2011, 07:20 PM   #1
jwo
Question
Spinning spindle on my washing machine
Hi all:
Posted previously about agitator/auger problem. I thought it was the cam dogs. Turns out the unit is inseparable. Installed the new unit only to discover that the spindle is spinning INSIDE the new unit. There is a corregated metal cap that fits over the spindle and meshes inside the agitator/auger unit. Problem is that the spindle is spinning inside this cap, nothing is agitating.
Has anyone come up against this before? The spindle doesn't seem stripped--it's smooth to begin with. Is there a trick to this?
jwo is offline   Reply With Quote
Old 09-12-2011, 09:04 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
no model number no help
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-13-2011, 03:46 PM   #3
jwo
Guess that would be helpful: 94802 / 94862
The unit is a "Laundry Center". I'm guessing the number on the left is the washing machine, the one on the right, the dryer.
Thanks,
J
Old 09-14-2011, 05:27 PM   #4
jwo
I have a better number, if you're interested: 417.94802301
Old 09-14-2011, 09:20 PM   #5
#1 HAWKEYE FAN
sorry, but I don't have a clue about what you are talking about. Your washer is a Frigidaire built unit, the agitator is a one piece unit. The agitator slides over the splines on the transmission shaft and then a screw holds it in place. If the agitator is in place and screwed down and it still does not agitate then you probably have a bad transmission. BTW, that unit is one big piece of sh**
Old 09-15-2011, 05:14 PM   #6
jwo
Hardwareman:
Thanks. you're right; it is a piece of crap.
The agitator does slip down over the splines on the hub, but the hub is a separate piece from the transmission. It looks like a large thimble. When I slip it onto the tranny spindle (that's not the technical name, of course), I can turn it, easily. It shouldn't turn at all. Could I have possibly STRIPPED the inside of the hub?
Tags
washing machine troubles
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Front Loader Fridgidair Washing machine Banging Noise when Spinning dads gt Appliances 1 04-05-2009 10:22 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
